I have a sealed box for my 2 12's and 2 15's. Each sub is in it's own compartment (as most sealed boxes should be) I REALLY like the sound it makes for every kind of music. Then again, i have no lack of power with an audiobahn high current dual fan 4000 watt ach power amp. If you run this badboy in .5 ohms you are really getting some power. Too much infact.
In reality, if you want a good hitting system. A 1000 watt amp, 2 12's or 2 15's (15's are more sluggish but deep, 12's "hit" harder and higher generally)
that can HANDLE 500 watts
RMS each. .... Peak power is complete garbage and should be completely ignored. I would recommend subs that handle 600 watts+ rms so you will get good life out of them. At this point, it won't really matter what kind of box you have because of how powerful 1000 REAL watts really is. Its unbelievable.
Word of caution. do NOT build a box with thin wood on "top" (top being the side you screw the subs in to and cut out etc.) It will bust the screws at 1000 TRUE watts and you will be pissed off breaking 1/6 inch screws and bigger. I wound up bolting my on with my old 3 15's box because i built it poorly. Just some advice for you first hand.
I would sell your set up if you want a LOUD system, and forget about making it look "COOL" Just don't trash-rig it. Keep it clean.
If 300 watts (If that is peak, you're going to likely be disappointed with your amps performance, and if RMS there's a chance that may be all you need) is what you want and need, then have at it. I am just an audio freak and im NEVER satisfied with anything.
Good luck and remember DONT HALFASS IT
