intelisevil
- May 11, 2006
- Sandy, OR
- '00XLT-SOHC,'99Mounty-5.0
The title say it all . . .
My '99 5.0 takes much longer to warm up than my '00 4.0 SOHC does. This isn't just a hand to the heater outlet test or looking at the gauge on the instrument cluster. I'm using an app getting signal from the OBDII port.
I start my engine and let it run enough to stabilize while I put on my seat belt and make sure my mirrors are good. I don't sit at idle to preheat my vehicles, trying to maximize my mileage. The only time I let my vehicle idle is if the windows are covered with snow or ice, I'll let it run while I clear the windows to be safe to drive. I drive down my 1/3 mile gravel driveway and turn onto a 55 mph country highway. My 4.0 is normally up to temperature (192°) in about 2 miles. 2.5-3 miles as the outside temperature approaches freezing.
Under the same conditions the 5.0 takes about 5 miles at 50-70°, about 7 miles at 30-45° and over 10 miles at 20° or lower.
I've only had the 5.0 for about 2 years. I replaced the thermostat last winter (before I had my OBDII reader) because "I knew" it had to be stuck open. Both the old & new (192°) thermostats reacted the same in almost boiling water but I installed the new one anyway - No difference.
That's when I got the OBDII reader so I could really see when (if?) the coolant got up to temperature.
I'm thinking about putting some sort of cover over part of the radiator (like the big boy truckers do in the Winter). Cold weather is definitely on its way and it's kind of hard to drive when your whole body is shivering uncontrollably because it's 20° inside your vehicle.
An engine block heater of some sort could help at home, but not when I'm at work at our local ski resort. The tree huggers have made it illegal to sit and idle to warm your engine up.
