Big Z
- January 22, 2010
- Nebraska
- '01 Sport
The correct tire pressure is the pressure that gives the best, and most even, contact between the tire and the pavement.
i agree
WOW, this much discussion over tire pressure!
Stop listening to these "tools" trying to scare you with talk of liability if you don't listen to them, insurance companies checking your tire pressure, roll over,etc.....
Sure, when you run out of rational arguments, insults are the best next thing! You are lucky that on this forum there is no moderation...B.) Ummm, again. Cuckoo, cuckooo.
My sticker says 26 on a '00 with 15" which simply MUST be wrong...I currently have the (non-OEM) tires at 32 and it feels pretty good...
i need some new entertainment here
Hmm, wonder if the engineers knew about some of us running at 8 psi when wheeling?
They should make a new sticker that tells us what psi to run for all conditions, topography, climates, sidewall makes, Speeds we run, for each type of tire ever made!
Be a pretty big arse sticker! LOL
Geeze, a little common sense is needed here guys. This is one of the wackiest threads I have read in a long time. Thanks! keep em coming!![]()
The OP obvious is at the first car/truck and probably a beginner driver. I am 100% that it has the OEM tires and it drives on the highway, otherwise won't ask this question here.Hmm, wonder if the engineers knew about some of us running at 8 psi when wheeling?
