Flashflood
There seems to be a misunderstanding of the design & use of auto A/C systems, and I'm going to attempt to help clear it up in short format.
In a properly charged and serviced auto A/C system (emphasis on this condition) ;
A) The Re-Circulating/ MAX setting is used to cool down a hot cabin of a vehicle that has been sitting in the sun.
It's purpose is to constantly re-circulate the cabin air over the Evaporator so as to quickly lower the cabin temperature to a comfortable level.
NOTE 1: When your A/C is operating in this mode, outside of the parameters of certain driving conditions such as Wide Open Throttle (WOT), the A/C compressor is operating almost all the time.
B) Then, once your cabin has cooled down to a comfortable level, you switch over to the NORMAL setting, so as to allow hot outside air pass over the Evaporator.
NOTE 2: The benefit of the NORMAL setting is that it takes the load off of your A/C Compressor from operating all the time.
It allows the Compressor to cycle on & off
as needed to maintain a constant cabin temperature.
The NORMAL SETTING provides a COMBINATION of having the A/C Compressor cycle on/off & having hot outside air pass over the Evaporator, ensures that the Evaporator will not ice up. This is what causes puddles of condensation to appear under your vehicle - which is normal and good - it shows your Evaporator is not icing up.
Bottom line: In a
properly charged and serviced system, using ONLY the MAX setting will eventually ice up the Evaporator, which will actually decrease the efficiency of the a/c system as well as put a lot of undue wear and tear on your A/C Compressor.
In conclusion: I suggest that you continue your quest to find out how to allow outside air pass over the Evaporator on your digital controlled A/C system.
HTH -
