Fuel pressure is controlled by the fuel pressure regulator and is adjusted by vacuum. You should have around 30-32 psi at idle. Under low vacuum conditions, (WOT) it will adjust to 40-42 psi. The fuel injector pulse width is set by the MAF, and adjusted by the o2 sensor. The MKVIII uses Pulse Width Modulation, to reduce fuel pump speed. This intern reduces the amount of fuel being returned to the fuel tank, thus reducing fuel heating, thus reducing fuel vapors. This is your "low speed fuel pump relay". The high speed fuel pump relay is located in your engine compartment fuse box. IT is grounded inside the VCRM upon command from the PCM. It is only used during WOT and when heavy loads are placed on the engine. If your codes 542 and 543 were current faults, the engine would not be running, as there would be no power to the fuel pump circuit.
Fuel System Description for Taurus Flex Fuel and 4.6L-4V Mark VIII
The Mark VIII has a DUAL FUEL PUMP VOLTAGE system ( «Figure 11» and «Figure 12») to aid in fuel system noise concerns. The fuel pump operates in the high voltage mode (12-14 volts) during crank (for 5 to 60 seconds depending upon engine temperature), after start-up, at engine speeds in excess of 3300 rpm, and during periods of Wide Open Throttle when maximum fuel delivery may be required. The normal operating mode calls for low voltage (7-10 volts) to the fuel pump. This minimizes operating noise. Fuel pump operation is controlled by the PCM. The fuel pump operates in the same manner as all other systems except for the two speed feature.
NOTE:
Maximum fuel pressure is obtainable at WOT or the vacuum hose removed from the fuel pressure regulator. If fuel lines/systems have been drained or evacuated, it may take up to 15 seconds to obtain the pressure specified.
