vipersinu2
- March 10, 2008
- The Big City of Orange City, Florida
- 2019 Navigator 450hp
put the input of the radio in sirus and it will have sound
No, its the factory ford navigation radio im using the lockpick with.oh you are using lockpick with that radio from trustigo?
not the factory ford radio?
FYI, you are a genius!! I got to reading that post and thought, hey wait a minute, let me go try something. My wifes 08 Explorer has Sirius, but we dont use it and it wouldnt even work with the aftermarket radio in her car. I went out and within 5 minutes was in business. I just removed the sirius module from her car in the kick panel, plugged it into the wiring harness that was already there in my 07 ST. I turned on the radio and voila, the SR tab was there. The sat radio doesnt work, but the audio from the lockpick DOES! Problem solved. Thanks for the idea man!http://www.explorerforum.com/forums//showthread.php?t=179253
there is alot of info here, from I am getting out of this it look like you can get the sirus radio module for 30 bucks, and then install a jumper behind the rear doors in the c piliar for audio.
then you will have the SR in put for sound for the lockpick
good luck
OK, new problem. I started the truck to go to work today and noticed the sat radio function was gone. I realized that when the truck is in the on or run position and the engine is off, it will see the sat radio box and work, but when the truck is actually on and the engine is running, it does not work. If I turn the key to on and then start the truck, the SR goes away. Anyone have a clue what thats all about? It's like the Satellite box loses power or something when the car is running, which makes absolutely no sense at all. My guess would be something with the canbus RAP system is messed up, which would also explain why my radio turns off when I turn the key off, even when the door is shut.awsome.
Just an update.. Everything is fixed and working properly now. I figured it out on my own, but later on when coastal tech support finally called me back, they confirmed that what I did was "a" correct way to fix the problem. I cut the 2 pink CAN BUS wires coming from the lockpick to the 16 pin harness on the back of the radio. The can bus + and - wires from the lockpick were interfering with the radio itself as well as the satellite tuner. That is why when I started the car, the sat tuner would turn off. It is also the reason my delayed accessory feature on the radio wasnt working. I can only imagine they have those connected to the lockpick in the first place to work for another model vehicle like the F150 because the Delayed accessory didnt ever work in my explorer once the lockpick was connected, even when I didnt have the sat tuner connected. By hooking the lockpick power up directly to the sunroof feed and cutting the can wires, all is well now finally. Hopefully it stays that way. It's been a long road getting this thing working. Definitely not a project for those afraid to deal with some problems.OK, new problem. I started the truck to go to work today and noticed the sat radio function was gone. I realized that when the truck is in the on or run position and the engine is off, it will see the sat radio box and work, but when the truck is actually on and the engine is running, it does not work. If I turn the key to on and then start the truck, the SR goes away. Anyone have a clue what thats all about? It's like the Satellite box loses power or something when the car is running, which makes absolutely no sense at all. My guess would be something with the canbus RAP system is messed up, which would also explain why my radio turns off when I turn the key off, even when the door is shut.
