2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Engine wiring harness installation (continued)
6. Route the crankshaft position sensor wiring to the sensor and connect it.
7. Route the voltage regulator wiring.
8. Route the TPS and MAF sensor wiring.
9. Route the engine temperature sender wiring and connect the connector (red arrow below).
10. Route the engine coolant temperature sensor wiring and connect the connector (green arrow above).
11. Connect the camshaft position sensor connector.
12. Connect the knock sensor connector.
