How to know if your transmission cooler is bad? | Ford Explorer Forums
1992fordgreen
Inside the Rehabilitation Center
95 SC400 92 SC400 96 Ex
What will happen? Will the tranny leak? Should it be hot to the touch?
Bump :)
They tend to get clogged if the fluid & filter are never replaced. This will cause a delayed shift or no shift if it's completely clogged. Later models transmissions have a thermostatic valve built into the valve body to bypass the cooler when it's cold, and open when it's hot. There is a cooler cleaner in a pressurized can for cleaning the cooler.
Thanks for the reply Brooklyn Bay. Would the trans leak if there was an EPC solenoid failure, or a trans cooler failure? I'm trying to track my tranny problems down
My trans was rebuilt and I put it in. Filter and fluid all new. Dipstick reads overfull but I'm still 0.2 quarts low.
This is on a 96 Explorer 4wd
The front seal is known to blow out under certain driving conditions when the transmission is running hot under a load. Sometimes fluid could leak out of the overflow vent on the top rear of the case if it's overfilled or filled while the engine is off.
delayed shift
Could you just use compressed air to clear it out? I have already changed the trans fluid and filter a year ago. I'm having delay and clunk problems going from park to reverse. I've read you can change the solenoid pack ($255)and this takes care of it.
Just read this and it goes per my problem. The overflow vent tubes never leaked the past 2 times I filled the tranny, engine off. The third time, as you know, the ATF leaked all over the place from the overflow. This is because the engine must be on to fill, correct?
Always fill & check the fluid level of the transmission with the engine running.
I know now...but why didn't the fluid leak out the overflow the first two times?
