Dano!
- September 14, 2010
- Lemoore CA
- 91 Navajo X 2
HOW TO
REPLACE ALL YOUR DOOR LOCKS AND YOUR IGNITION
Background: When i bought my second Navajo, it came with a busted ignition, the previous owner told me i had to use a butter knife to start the truck, and he was kind enough to give me a spare just in case i lost it. Later my daughter ended up breaking the key off in the driver door lock, and i decided it was time to replace everything. So here Goes!
Tools Needed
Phillips and Flat Tip Screwdriver
8in long Flat tip (to use as pry bar and punch)
Door retainer remover tool
Flashlight
Small drill bit 4in Long
Total Time Start To Finish => 3 Hours Being Lazy
First The Door Locks
Step 1:
Make sure your windows are rolled up and that your battery is disconnected. Start removing the door panel by using a Phillips screwdriver to remove these three screws. You need to take the plastic cover behind the door handle off too, this can be removed easily by hand or with a flat tip screwdriver. Once the screws / cover are removed you can pop your door panel off. The door panel is held in place by many black plastic retainers as you can see in the second photo (bottom of the door panel). my retainers were messed up and easily came off the door. you can purchase a specialty tool to remove these properly or you can do as i did and replaced all of them, as they needed to be replaced anyway. Also there is a small slot on the bottom of the switch panel (lock / window) that you will want to take a flat tip screwdriver to to pop the switch panel loose from the door panel.
Step 2:
Once you have the door panel popped off you need to take care and not rip this bulb out. you need to twist it Counter-Clockwise to get it to pop out. Now that the bulb is removed you can twist the switch panel that you loosened in step one through its opening and remove the door panel and set it aside.
Step 3:
This is where the door lock is inside your door panel. There is a piece of metal that is a fork with a lip that holds your lock in its place, all you got to do is reach in and grab the lip and pull it off. (as seen in picture 4) It may be a PITA but it will come off, set it aside for now.
