oplitic
- May 5, 2006
- Deering, NH
- 98 Mounty
wow yeah doesn't sound like i'll be doing this. Its not my car its my step dads. he can pay 250 to have it fixed
Just put it back in...
lol. It's not too bad taking it out. But putting it back in sucked. You need to twist part of it back and put in the bolts holding the motor to the bracket only a few twists. The bolts need to be loose enough so that when you twist the twist motor more to get the window gear in, it can go under neath the motor's gear, so when you tighten the bolts, hold it in place, and push on it to get the motor's gear in it's place, the teeth on the motor's gear and on the window gear will go together. Then after all that you need to figure out where the window needs to be so the holes will line up to put bolts in where the rivets were.
Before I put it back in I connected it to the switch and it worked fine!! Took it out for nothing. I can roll it up and down no problem, no binding or anything. It was just like Pensa, except I tried going all the way up and down and it never stuck again..
