how to run Power wire? | Ford Explorer Forums
shutout31
Alberta
92 XL
I am trying to install my subs in my 92 Explorer but cant find a good place to run the power wire to the back cargo area. Any help would be awesome and i am running 8gauge wiring also. thanks
Go through the holes that are already there on the firewall. There should be a nice large rubber fitting type thing that you can stretch out enough to fit some 8ga through. After that go under the carpet with the rest of it.
right above where the throttle cable leaves the cab to the engine compartment there is a unused hole that a rubber plug will be in its place.
run the wire in the rocker panel along side the harness track, under the carpet. to get the rocker cover up just pull it upward it will peal off.
stuff the wire under the rear quarter interior trim panel, till you get to the end of the rear seats.
after that it all depends where you plain on mounting the amp??
Dont run it with RCA's or speaker wire though, take a different route.
good point... run the rca's on the other side.
if you run them next to the power you will get feed back and stuff
