How to wire up tweeters | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Metallic2001
charleston, sc
1994 explorer limited 4x4
I have a 94 explorer and I want to install some tweeters. My question is, do I wire the tweeters to the door speakers or somewhere else? Thanks for the info.
Marshall
Alec
Elite Moderator
Moderator Emeritus
Houston, Texas
2008 JK
Get a component set with crossovers, mids, and tweets to replace your stock coaxial door speakers.
Bill Kemp
Elite Moderator Emeritus
Moderator Emeritus
Greenville, MI
98 Mountaineer 5.0 AWD
I have wondered that also.
Can you just tie the wires into the speaker wires in the doors for a seperate set of tweeters?
'96explorereddiebauer
Clemmons, NC
'06 Honda Accord EX-L
Hmmm...sounds interesting. Can I just tap into my stock speaker wires?? I'm not really worried about the bass since my stock JBL system already have a crossover built in so the only bass I get is straight from the sub instead of the door speakers.
bigred93explrer
Albuquerque, New Mexico
1993 xlt
You need to get some that come with crossovers or get crossovers. The tweeter wires into the crossover and then you can tap the other end of the crossover into the door speaker wires.
Clemmons, NC
But mine came with a stock crossover already. My system's door speakers don't produce any bass at all. The only speaker that produces bass is the stock sub in the back. Do you mean that I still have to install crossovers with the tweeters?
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
If you wire tweeters directly to another speaker you and changing the impedence load on the amplifier, not good.
You cannot just wire tweeters in on all the speakers, not unless the amp or deck han handle the ohm load.
You dont have to have a crossover for a tweeter, you can use a capacitor to remove all the low and mid freiquencies, but it is best just to replace your stock speakers with some co axial or components as mentioned above. Otherwise like I said you will destroy the amp or deck or both.....
