ccanuk
- April 7, 2004
- Saint John, New Brunswick, Canada
- 94 XLT
Hi I'm looking for some new thoughts onto a few options I have to convert my X to electric/Gas Hybrid
Eventually I want to put in a smaller Diesel in place of the V6, but for now I want to get the electic part installed, before changing the Internal Combustion power plant
the basic idea is that the electric system will charge when the engine is under light load, and apply an extra equivelent 50hp when under load or accelerating.
this is close to the motor I would be using, the difference would be that the motor would be cabable of generating also
1) remove the transfer case and run a drive shaft from the Tranny straight to the rear diff, and mount the electic motor/generator onto the front drive shaft.
this will allow me to upgrade to full time AWD, and I can swap out the gears in the front to suit the motor, but I loose my low range, and the electric motor will not be as powerful as engine so power from front to rear will be unbalanced.
2) move the transfer case back a bit, and install the electric motor/generator between the TCase and the Tranny
this allows me to keep my low range, but requires a lot of fabrication, and possibly will need a system of gears to get the motor's power matched to the engine
3) mount the motor between the TCase and the front Diff, If I understand correctly, this will allow the front wheels to be driven by the motor while the TCase will spin freely, until I engage 4WD, in which case the TCase will engage, and provide power to the front to supplement the motor.
This would probably be a halfway between the 3 options for difficulty, and would allow me to have AWD, Fulltime 4WD with a low Range, and in 4WD the power between front and back would be more closely balanced. the only problem is in low range the motor would not be able to supply much power to the axle with out risk of burning it out
what do you all think?
