jtf_explorer
- May 18, 2005
- Lansing, Michigan
- 1994 - 2 Door
Well guys and gals, I am in the process of installing the skyjacker ranger 4" class II system on my 94 explorer with rear superlift 4" springs. The rear is finished. I already tore apart the front, everything is painted, and things are going back together. I am a bit stuck though. when I try to put in the passenger side Extended Radius Arm mount in place of the tranny crossmember, the bracket won't fit flush against the frame rail because the frame rail isn't straght like the bracket, it comes out a little making it were I can't get the bracket up enough to put in the 2 bolts. Also, the driver side frame rail doesn't have the 2 holes to bolt in the R.A. bracket, you are suppose to bolt in 2 bolts on the side and drill the 2 holes in the bottom for 2 more bolts, but there are no holes on the side. How do I install that bracket as well. Thanks for the help, the susp lift is so close to completion, so then the 3" body lift can get started.
