I need help with my 1999 Ranger. | Ford Explorer Forums
RodneyF
Amarillo, TX
99 Ranger
Need help with 99 ranger. Was running fine. Turned it off one night would not start next morning. Starter, Battery & ignition switch tested fine. Am not getting voltage to solenoid terminal. Any ideas from here? Thanks.
99 ranger
Talking about power to starter solenoid at starter. The truck has a relay rather than solenoid. I checked the fuses under the hood and all checked ok. I am going to check the NSS today. Any suggestion on the NSS pin configuration to by-pass the switch?
To Brooklyn Bay
Thanks. Any idea where it is on the frame? Can't seem to spot it. Only relay I find is in the fuse box.
