- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Penzoil Ultra is NOT a true full synthetic. It is a group III+ base stock with PAOs and Esters added. The difference between it and Platinum is the additive package, which it uses to attain an extended drain interval so they would have a product that directly competed with the Mobil 1 synthetic's extended drain interval.
Since when did Pennzoil change their oil? I'm not going to go back and forth with anyone about one detail, but they were a pure synthetic oil the last time I checked a couple of years ago. Theirs cost a good bit more too back then. Now it's about the same cost, was that a transition after they did something?
Many lesser quality OEM type of paper air filters do restrict airflow notably after a few months of typical use, reducing MPG enough to measure that. I agree that "high flow" filters like K&N are poor choices for filtering dirt well. The oiling issue is another problem too.
Its best to find a quality paper or micro fiber filter which doesn't require oiling, and change it at the proper interval. Thus Amsoil filters are an ideal choice, they filter very well and should last four years with proper cleaning. That is cheaper usually than any paper filter costs.
