neo1973
- March 2, 2012
- Vancouver, WA
- 1999 EX
So, fiddling with the dying Explorer and replaced the PCV. No improvement. So I start back at square one and start looking at the vacuum line and IAC. I take off the block under the IAC that attaches to the manifold and give it a squirt with solvent and blow through it to make sure it's not blocked. Seemed ok. I also cranked down the screws on the IAC to make sure it was nice and tight, and got about 1/8 of a turn out of both of them. Started it up and the noise seemed to be quieter, but still present.
My questions are: my IAC came with 2 gaskets, 1 paper and the the rubber figure 8 one. Could the paper one be letting air through? Am I suppose to use both?
Also, can that block under the IAC cause the humming if one of the ports is clogged? What I mean, has anyone heard of that before?
