redrockexplorer
- July 11, 2007
- Utah
- 1993 xlt 4x4 4dr
MY 93 explorer IAC does not work for 1min to 10min after starting engine. It seems longer it sits unstarted longer IAC takes to start working. Relaced couple IACs decided it was not the problem. Runs fine after IAC starts working. Replaced left O2 sensor, codes 176 and 177. Only code it has now is 629 and it has had this code the whole time i've owned it and the TC lock-up works fine. Read on here to check ECT and IAT sensors. The IAT metered ok, ECT metered open so I replaced it. MAF has been cleaned and TPS is at .94 volts. Still having same problem. Then I remembered my meter also measures duty cycles. so i back probed IAC connection. The IAC is not getting a signal from PCM until it works. I have cleaned the connections at PCM and the 2 beside the alt is there any connections i'm missing? Could a sensor hold out the PCM from sending signal? Or is my PCM bad?
