- June 16, 2003
- Humboldt, KS
- 2000 Mounty
OK
I was pulling this adjuster plate Which SVO sent, I am now sending it on to Dreamr.
In the process, I decided to look real hard at my IAC valve.
In regards to this "issue" I am fighting
http://www.explorerforum.com/forums/showthread.php?t=167231&highlight=surge
I have a handle on the surging, however the idle hangs, as in when engine is revved, it hangs at about 1800 rpms for a few seconds, then settles back down--there is a video of this in above link
Ok it is a tuning issue.
On to a few thoughts and questions
I sprayed some electronics parts cleaner into my IAC valve-which of course has been replaced and replaced again, and questioned-
I noticed the valve inside rides on a shaft, which feels like it is on a diaphragm, rather than a spring. It also does not close all the way by itself.
I also experimented, thinking it was on backwards--nope, engine vacuum holds it open when reversed.
Does the vacuum hold it closed? ( when installed correctly)
Or
Is this a linear motor, with a variable polarity voltage operating in both directions?
See where I am going?
I am kicking myself for throwing my old one away--I would sure like to see one dissected-----
Or
