Originally posted by briwayjones
Ok I accessed the wire in the bundle under the door trim. It seems to be the right wire because the 4wd will affect how the switch works. I'm having trouble getting it wired right. If the switch is wired right and the switch is in the off position should the 4wd light come on when you engage the knob? If it should come on the 4wd just won't work? I think I had it wired right at one point because with the switch in the on position and the 4wd engaged the LED on the switch would come on, but if I turned the 4wd knob off the LED would turn off. Is that correct? Also I want to make sure of something. There are two wires that come off of the back of the cigarette ligther. One that should be the hot wire that goes to the center and a black wire that connects to the side, that black wire is a black wire right? I'm using that one to ground my switch.
Thanks guys.
