IFS Dana 35 gears | Ford Explorer Forums
IFS Dana 35 gears
Josh C.
Live in: Santa Ana, CA - - - From: Oshawa, Ontario
1998 Mounty v8 AWD
As far as I know any standard cut D35 gears will work, its not a high pinion reverse cut. So even a set for a jeep D35 rear should work, but I could be wrong.
If I read other post correctly the shafts on the pinion are different
I think the yukon gears you have listed are the right ones you will just need a different rebuild kit to deal with the ifs.
