Subscribing. I've got the original msd dis4 that I bought years ago when I had my supercharged OHV and might try installing it on my 2004
Do you still need the plug wires?
Yes, the coil packs should be the same. Ford only used 2 different style 6cyl coil packs... The only difference between them was the angle the connector attached at. (They use the same connector.)
I may a 36-1 wheel and crank sensor around, if you want to do it mechanically.
Below is a block diagram of a possible dual coilpack design that increases the spark energy of each combustion plug while avoiding the issues with combining the high voltage outputs of each coilpack. The design incorporates Insulated Gate Bipolar Transistors (IGBTs) triggerred by the PCM to control the current flow thru the coilpack primaries.
In the stock waste spark system illustrated in a previous post the output voltage required to fire the plug on the compression stroke is dependent on the gaps and pressures between the gaps of the paired spark plugs. The gaps for both plugs are the same but the chamber pressure of the compression plug is much greater than that of the exhaust stroke plug. Ford justifies the waste spark design by arguing that the voltage required to fire the exhaust stroke plug is much less. If the voltage required is directly proportional to pressure then the exhaust stroke plug may require 3,500 volts while the compression stroke plug may require 35,000 volts (static compression ratio of the SOHC V6 is 9.7:1). For a series circuit the current is constant thruout the circuit. Power = voltage * current so for this example one tenth of the power is wasted. The circuit above eliminates the voltage (and power) associated with the exhaust stroke plug when the compression stroke plug is firing. Assuming the power in the coil primaries remain the same as for the stock configuration, the spark power will increase by 10%. It may be possible (by using high current IGBTs) to increase the power in the coil primaries.
By determining (experimentally) the phase relationship of the primary to the secondary windings it is possible to achieve current flow in the same direction for all spark plugs. At this time the (+) shown on the windings is purely speculation.
One disadvantage of using the IGBTs is their added switching delay which impacts the timing of the spark initiation. Fast IGBTs are available with turn off delays (when the primary coil field collapses) of 100 nanoseconds (0.1 usec). For my stock rev limit:
6250 revs/min *1 min/60 secs *360 deg/rev * 0.1 usec = 3.75 degrees
This delay is not major but may be enough that retiming might be needed for optimum performance. Retiming can be accomplished with the SCT Pro Racer software package.
This scenario seems to be basically building a COP style setup (without the actual coil on the plug.... but essentially one coil winding per cylinder).
I don't fully understand the purpose of trying to run dual coilpacks to fire one plug twice theory. Nissan ran 8 plug 4 cylinders in the late 80's due to emissions purposes but it's been reported that it had essentially no effect on the gas mileage.
I know that in the Escorts there were 2 variants of the EDIS4 units... red vs. blue sticker units (don't know exact part number) and that it's rumored the blue (less common) had multiple spark discharge setup at idle speeds to help. I would think that Ford would include this especially on larger engine'd vehicles if it was something that would help marketing (and SUV's/gas mileage is a marketing point) but it doesn't appear it was.
. . . If you really wanted to improve the mileage of the vehicle you'd be better off watching tire pressures, making sure your O2's are reading correctly, no exhaust leaks, running the lowest octane fuel w/o pinging, and then working on drag the vehicle has & areas that can be improved on the exterior (for example wheel covers). . .
Hey Dale, I dug up some wires for you. What else do you need?
Get a good baseline of your MPG for a month or 2. Then track it after the install and report back here. I'd like to see if you get similar results as me.
You mentioned that you might have a 36-1 tooth trigger wheel. I found one on eBay Universal 36-1 variable reluctor/trigger wheel for about $15. It is only 5 inches in diameter but has a 1/4 inch dia. hole which makes mounting on an electric motor easier. If you have a variable reluctor that would be helpful.
Any Ford with an EDIS unit will have a 36-1 wheel. Usually these are taken from Ford Escorts as they're pretty easy to get off the vehicle and then the wheel is only pressed onto the crank pulley (little heat and a tap of a hammer - they fall off). They're easy to find at junkyards and if you get the wheel off in the yard they probably won't charge you much.
If you really like to experiment you might want to consider going with an aftermarket unit like Megasquirt.
My 87 MR2 had a Japanese supercharged engine (higher compression, higher boost, reconfigured head) that I was running on Megasquirt. I was able to turn the s/c off (uses an electromagnetic clutch, similar to an a/c pump) and tune the MS for those MAP ranges. SC on I could tune much more aggressively. I was able to yield all of 14mpg with the s/c on but a surprising 45mpg with it off (note: a stock first gen MR2 N/A will be at about 30-32mpg for highway driving).
I'd get the wheel off Ebay if I were you. If I do have one, its off a balancer and will have a 4" (?) hole in it.
I'll send you a crank sensor or 2 with pigtails.
Thanks. I purchased the 36-1 trigger wheel. Looking forward to receiving your items. You've been a great help with both of my recent projects!
I only need the 36-1 wheel for table top prototyping.
I agree that a Megasquirt system is for experimenters and possibly appropriate for single use vehicles (dragsters, circle track racers, etc.): MegaSquirt systems?
Very interesting. Did you have a centrifugal supercharger? Was there a supercharger bypass for when the electromagnetic clutch was disengaged? Does Megasquirt allow real time switching between two sets of air/fuel ratio and ignition advance tables?
