I'm looking for a door lock wiring diagram for a 1998 Explorer XLT. | Ford Explorer Forums
rkb2694
Woodbury, MN
1998 XLT
looking for door lock wiring diagram!1998 expolrer xlt. Drivers door lock switch locks but doesn't unlock.
Welcome to the forum! I'd suggest you head over to the 95-01 Explorer Section. They'll get your issue solved. I have a similar problem with my 98 EX. Its unlocks but doesn't lock. You'll probably need a new lock/unlock control.
The inside of the switch may have gotten rain in it. Sometimes some contact spray helps. Other Times the corrosion is worse.
Might just be a broken wire due to flexing every time the door is opened or shut. Pull back the rubber boot between the door and the front fender and inspect that bundle.
