Im lost, haha, what rim size/offset do i need for 285/75 tires, 2004 Explorer? | Ford Explorer Forums
Skip01
'04 XLT
Well i have 285/75 rims on my stock rims at the moment...and im growing tired of looking at them stock:
Im looking at keeping the same tires, so 16", but theres different size widths and offsets:
Looking at either these: http://www.ntwonline.com/TYPE_52_BLACK_-_PRO_COMP_WHEEL_P14289C45.cfm
Or these: http://www.summitracing.com/search/...heel-Diameter/16-in/?Ns=Rank|Asc&autoview=SKU
Heres a pic of how close i am too the control arm:
Its close but i still have daylight betweem.....maybe i should get some spacers with it as well?
As i said, lost....haha, any help is appreciated
helps?
Thanks man, I was hoping they'd have one I could use that didn't need wheel spacers. Diidnt wanna run them and add stress on parts.
The 0 offset and 4in backspacing withh bring the wheel lout some or be about the same as stock rims?
Someone will correct me if I'm wrong, but anytime you change the overall geometry of the wheel, whether through the use of spacers or with different offset, you will put some level of stress on the steering and suspension components.
The 0 offset and 4 inch Back space will bring your tires out past the fenders and give you a nice look. Added a bigger offset and backspace does add a little stress like DIVEMASTER said. There are alot of guys on here running wheels with larger offsets and havent had any problems.
yeh it does, that's why I didn't want any extraaaa from spacers ha.
Dont run spacers then.
Any idea how far they will stick out?
What's the width and offset on your stock wheels? If it's the same as my '07 (7.5" wide and 44mm offset), then they'll stick out almost 2", if my calculations are correct. I have 17x8 with a 20mm offset on mine, and they stick out almost 1.5" over stock.
Size: 16" x 7", 5 Lug, 4.5" Bolt Pattern, 44mm Offset
I have the same size of tires, but plan on using stock rims. I have been searching for a thread that will tell me how thick of a spacer I need to run them. I tried to put them on the other day and the tire shop said it was rubbing on the upper a arm. I didn't get a chance to look at it, much less measure how far out it needed to go. Since it appears that you are running that size without any spacer, I assume I don't need much of a spacer. Is anyone running this size with a spacer and stock wheels?
bump....
