johnrhadfield
- January 31, 2010
- San Angelo, Tx
- Ranger '2000
I need advice. I want to buy a simple tow bar. That's no big deal. I want to tow my Ford 2000 Ranger. I have spoken with some trailor welding shops and even talked to Ford. I am not sure if there is even a tow package available to connect to the front bumper of the Ranger.
I am thinking of removing the front bumper completely thereby exposing the four bolt holes (2 on each frame rail) and then there is another bolt hole on each frame rail I guess about six inches back from the front on the side of each frame rail.
That's 3 bolt holes on each frame rail. So to that I want to put 2 plates up front on the sides on each frame rail. Then I want to tie the 2 frame rails across the front with a crossmember across the front. To the crossmember I would then bolt on the tow bar. I am told the crossmember is necessary to make sure that the UNIBODY is not bent. That is my major concern. I do not want to bend the UNIBODY when towing my Ranger. I think this is a sound plan, but does anyone have any better ideas or cautions to this plan?
John
John
