Yep very easyI don't understand it either I just remove the inner fender plastic and install
ratchet And Wobble and extension
yeah it isnt bad, find it easier to remove the tire and inner fender, then its an easy ish job.Yeah ive done this job several times and its a 45 minute job at max for me
Do you recall, how many extensions and what size wobbly? Planning to change my plugs, have no idea how old they are or where their gap space is at now. So I can get the tools and have them ready! Shouldn't have to jack up the Ex either.I don't understand it either I just remove the inner fender plastic and install
Thanks! Think I'll get an assortment of long and medium extensions. Sounds quite doable.3/8 wobble adapter
5/8 spark plug socket
A couple of extensions
IIRC I used a 3" straight extension and a 6" wobble (not together, used different configurations on different plugs). Since the spark plug sockets are already deep, you don't want too much extension or you'll start running into other things with your ratchet (heater core box being one).Do you recall, how many extensions and what size wobbly? Planning to change my plugs, have no idea how old they are or where their gap space is at now. So I can get the tools and have them ready! Shouldn't have to jack up the Ex either.
I read somewhere a long time ago that when you change your spark plug wires to keep one of the old ones, cut it to about 2' in length from the boot end. And then use it to start all your new plugs in the future. A sparkplug wire boot is the perfect tool to grab a sparkplug and start it without cross threading it.I like to put a rubber hose on the end of the spark plug to aid and screwing the new one in without crossing Threading it
Very helpful. Thanks. I think I have these already!IIRC I used a 3" straight extension and a 6" wobble (not together, used different configurations on different plugs). Since the spark plug sockets are already deep, you don't want too much extension or you'll start running into other things with your ratchet (heater core box being one).
