ptf18
- June 5, 2012
- 2002 Sport Trac
Fellows: I removed the throttle (?) body from the manifold of my 4.0l V6 in order to gain ez access to the upper radiator hose connection at the thermostat housing.
Looking into the manifold I saw that I had "liquid" sitting in the bottom of the manifold. Turns out to be oil.... and to me alot of it. Maybe a pool 1/4" deep.
I used rags and towels to remove this oil but I'm concerned.
The engine runs fine and I dont notice it "burning" oil. Oil level stays up although I do have a oil leak which I thought was/is the oil filter adapter.
I'm thinking that the PCV valve is allowing this to pass into the intake system. I've got a new valve (Ford) and new hoses (the ones that usually deteriorate) which I intended to replace at a later date.
Thoughts on the source of this oil? Engine has around 85K on it.
