Intake Plenum Gasket Question | Ford Explorer Forums
bunky827
new bedford, ma
97 Explorer XLT
I just removed my lower intake and replaced the gasket. The kit came with 2 plenum gaskets. Do these both go between the upper/lower intake manifolds? Thanks
There are two gaskets regarding your intake manifold. One fits between the fuel rail and the upper intake, and the other sits down in the valley, and is a much different design than the upper intake gasket. Not sure if that is what you needed to know, but I figured I would just throw it out there!
My question is referring to the gasket between the manifold and fuel rail. The kit supplied 2 of these identical gaskets along with the valley gasket.
one gasket goes between the fuel rail and the lower intake, and the other goes between the fuel rail and the upper intake.
