Spartan
- September 24, 2009
- Sun Prairie WI
- 1996 XLT, 5.0 2WD
Well, it was bound to happen sooner or later...
So... a month ago, I bought my wife a 93 Taurus SHO. The jokers who had it prior to me didnt do the front 60K service correctly, and it pissed out a bunch of oil. (front crank seal). We get it back, and 10 miles later the trans goes out. (auto)
While waiting for that to get fixed, we put the explorer on double drive duty. Its been ran a lot in the last few weeks, and yesterday it dies completely. Here is what I know:
3/4 shift solenoid is inop, and it throws a KOEO code for it. I still have TC lockup.
When it died, i was thinking it was the EDIS module... until i realized I had no CEL on startup and no fuel pump running. Traced the problem down to the EEC fuse blowing out. All three underhood relays (under the dist box) were replaced, still blows the EEC fuse.
I did some searching, and it appears that the 3/4 solenoid has power at all times when the key is on, and it actuated when the EEC grounds the other side of the circuit.
the EEC fuse blows within seconds of the key being turned to the "run" position. Until it blows, I have a CEL like normal.
I'm guessing at this point that the 3/4 solenoid was stuck (old fluid from the previous owners neglect) and finally got hot enough to melt the internal trans harness and ground out the circuit.... blowing the EEC fuse. After reading, I see that this is actually pretty common. Since I knew that the 3/4 solenoid was having issues already, would this explain my problems? the truck is on the side of the road at the moment, and i have no money for a tow.
One quick question: I cant get my man-arms up next to the trans to disconnect the 3/4 solenoid/tc harness, but I hear that there is possibly another connector somewhere on the drivers side fender apron.... does anybody know what I'd be looking for? I want to disconnect that harness and put a new fuse into the socket to see if it blows. I'm almost certain that this is the issue, since the 3/4 solenoid has been inop for a long time.
