Interior lights not working | Ford Explorer Forums
doc dukes
Fairfield,Pa
94 XLT
I need some help on where to look to start tracking this problem down. My interior lights don't come on with any of the doors open. When I try to turn them on manually with fuse blows out. Its the same fuse that the radio is on. Just checking to see if anyone has had the same issue if so what they did to fix it. This is on a 94 XLT. Thanks
you have a short somewhere. Do you have door plane lights and a dome light? probably simple enough to unplug the dome light and take it from there. Make sure you have the correct amp fuse. If with the dome disconnected the fuse does not blow, I would look between the fuse and the dome. If it still blows, start looking at the doors
