My truck is a 95 4WD 4.0 SOHC with factory power electronics (seat, windows, doorlocks), theft, and towing packages.
Over the past several weeks, my '95 fails to start intermittently. The starter will spin the engine but the engine fails to catch. After a period of time, about 30 minutes, the car will then start. The problem only occurs on start up, it never dies when running.
I've had this to a mechanic, but the problem never surfaced for them. In addition, the engine light never came on therefore no engine error codes to use as clues.
I thought it might be related to the Locktronics security system but the Dealer reported that the started's power would be cut which rules it out.
Intermittent electrical problems have also arisen in other areas which may be clues: 1) intermittent wiper speed fluxuates, 2) auto door locks are not consistent in operation (sometimes they unlock).
If I remember my basic auto repair, you need fuel, spark, air, and compression for the engine to operate. The intermittent no-start would eliminate all but the fuel and spark I believe. I could rig up a fuel pressure gage and spark indicator to narrow down the possible causes.
Any advice would be appreciated!
