koda2000
- September 2, 2011
- x
Thanks again she probably won't see any off roading just want her to be solid I'm buying it off my brother and he doesn't maintain his cars the only thing I can say about it is the engine seems to be solid other than the oil pan gasket which from what I've read on other post that will be one job that she goes to a garage for
Sounds like a plan. If you find that jacking up the rear a bit levels out the truck, I'd consider the Monroe Load Leveler shocks for the rear. Search the forum for "gangsta lean" or "sagging springs". This subject has been covered many times and in most cases the Monroe rear coil-over shocks have solved the problem with minimal effort and expense.
As a side note... I once had a classic vehicle that was very low (2 inches) on one side. I was sure the problem was that the original front coil spring had sagged. I replaced the front springs (at considerable cost and effort) and to my dismay it made no difference. I ended up adding a 2" raising/lowering block between the rear axle and leaf spring to solve the problem. An easy fix at a cost of about $15.
Good luck and let us know how you make out.
