Is this a good head gasket set? | Ford Explorer Forums
any have an opinion on this set?
I have used it....
And so far after 25k on the new engine the gaskets have worked as designed...
Just make DAMN CERTAIN to lube the head bolts with the anti seize included or the torque readings will not be correct...
Oh and I did not use the valve cover gaskets included; I went with the Felpro neoprene gaskets and I coat them with Avation Form-a-Gasket to keep them in place and to help them maintain an oil seal...
I have recommended these gaskets from this vendor in the past...
Thanks I will order them today
