lightningrodbob
- December 23, 2009
- 98 Eddie Bauer V8
It looks good, but it's a V6. I cannot stress how much more reliable the 5.0 is than the 4.0sohc. With 142k miles on the clock, it would be imperative to see documentation showing that the timing chain tensioners have been replaced prior to me even considering it for purchase. I would also be very leary of the transmission if it hasn't been rebuilt.
I'm not trying to burst your bubble here or anything, but you've got a mountain of useful information at your fingertips here on the forums. Take advantage of it and research before you buy. There's a reason why I've owned one 4.0 and three 5.0s.
It has a selectable 4x4 switch on the dash and no V8 badges on the fenders. It's highly unlikely that the person shaved the badges or replaced the fenders and also replaced the radio trim bezel with one from a V6.
It sure looks like it's a 5.0, aka a 302ci, V8. Of course, someone could have slapped the badges on it, lol. As for the 2WD or AWD thing, I'm going to go out on a limb and say that it's most likely AWD. 2WD 5.0 Explorers, at least in my area, are few and far between. Shoot the seller an email and ask them to verify if it's a V8 and whether or not it is 2WD or AWD.
So can anybody break down why exactly the V6 is so unreliable compared to the V8?
The basic block design of the 5.0 has been around since the early '60s. The 4r70w tranny used with the 5.0 is darn near indestructible. The same can not be said for the V6 trannies. The SOHC V6 have the timing chain cassette issues. Not a cheap or easy fix by any means.
I noticed the Craigs list link for the Explorer in your original post has been pulled by the lister.
Are all the V6's the SOHC you're referring to?
So is this one a V8 then?
http://losangeles.craigslist.org/wst/cto/1521334155.html
If so, it will probably turn out to be a 2WD, thats my luck haha.
So whats better 1997 Ford Explorer V8 with AWD or 1997 Ford Explorer V8 with 2wd?
No. Ford used 4.0 OHV & 4.0 SOHC engines in the Explorers. The SOCH has been in use since the 1997 model year but was not standard as some hve the OHV in their 98's & 99's. I think (but don't quote me) that the SOHC became standard in 2000.
So is the OHV preferred to the SOHC?
I don't think they're particularly preferred, especially since they are down 45 horsepower compared to the SOHC's, they are just a heck of a lot more reliable. But keep in mind all the V6 Explorer's have pretty weak transmissions. You would probably have a harder time finding a OHV V6 than a V8 anyway since most of the relatively newer Explorers have the SOHC V6's or V8's. If I had to buy a V6 Explorer it would probably be a SOHC that would be checked out extensively. Regardless there are so many V8 Explorer's out there that you should just continue to look for those.
