Jack Stands | Ford Explorer Forums
Jack Stands
302Xplorer
Richmond,Va
'00 XLT
I am getting ready to change the spark plugs, going to use Motorcraft Plats, on 2 explorers. I need some jack stands but do not know what I am looking for. Some guidance would be appreciated.
Thanks in advance,
302X
Funny-
I just learned with 31" tires, 6 ton are just not quite large enough ( to use the frame pads) , yet I need 2 blocks of wood under the jack pad to get it high enough for 12 ton stands.
Do you have to lift it for any particular reason? I thought for spark plugs you could just lean over it and do it? It is just the difference with the engines? Where are the plugs in a V8 located?
