James Duff lift help... | Ford Explorer Forums
Kris Guilbeaux
Elite Demon Secretary
Staff member
Moderator
Austin,Tx
92 Nav, 99 Mounty, 98 Ex
I am going to buy a James Duff 2.5" lift for my Navajo but I know there is a way to modify the lift for 3"-3.5" If any of you have done this can you give me the things I need to modify the lift. Also I want to run 32" tires on the Navajo once I put on the lift. I will run stock rims. If any one has pictures of the modified JD lift on a 2dr. will you send them to me.
Any help would be nice.
I am unknown on lifts...I was wondering how the 4x4 conversion is going...
My out put shaft for my trans is on backorder and should have it by tues. Untill then the parts remain sitting in my garage in front of my 2wd Navajo
I did some research on this, before I bought the 5.5 superlift.
To go from 2.5" to 3.5" with the james duff, you:
1) install 1" coil spacers in the front.
2a) replace the rear shackles with the warrior shackles.
or
2b) replace the rear spings with the OME springs.
2b is a new option.
That's it. simple eh?
Tdavis is right.. a 1" spacer will lift the front.. The scary thing is that even without the 1" spacer (I haven't put it back in since I test fit it).. we are lifted 3.5" over the old stock height.
We are using the Warrior Product Shackles which gave us another 1/2" over the height with the Duff shackles. Our old springs have 196k miles on them (rear) and I'm sure they aren't as high as they need to be. Before I can put the 1" spacers on I have to finish the Rock Sliders (with steps) so Yolanda can get in the truck. She is only 5' and the truck is almost too high as it is.. If I make it so she can't get in her truck I'll be out in the dog house for a LONG time. Once the spacer are in I will replace the rear springs with a new set to level things out.
