OKay I have some experience with this.
I had a Duff stage 1 3" lift on my BII (dana 35 same as Explorer)
I also had the F-150 coil spacers. You will not be able to align this setup.
The problem is even though Duff advertises the lift as a 3" setup the axle pivot drop brackets are actually 2" tall (over stock) so with a 3" coil and a 1-5/8" spacer your camber will not work. You will be left with + camber and it will eat up tires like crazy.
I tried everything to get this setup to work. The larges camber shims available for a 4 wd are 2.75 degree's. Even with the shims maxed out you will have + camber.
With the correct wheels (15x8 with 3.5" offset) you should be able to clear the 32's. If not youcan make your own coil spacer (see therangerstation.com) and keep it to 1" max)
Also keep in mind all tire brands are different. SOme companies 31" tires are larger in diameter than other companies 32" tires.
Personally I think if they rub a little its not a big deal, also you can always use a sawzall or hammer to make clearance......
I was not happy with the Duff lift for a few reasons. The duff VR coils are TOOO stiff, and and the 70/30 shocks are WAY too stiff. Their drop brackets are top notch quality and strenght however.
Now keep in mind you will install this Duff lift, fit the 32's and be happy with it for about 5 minutes before you want to go bigger.
I currently have a 6" lift on my truck, using Skyjacker coils, Skyjacker radius arms, Rancho 9012 shocks, and Duff axle pivot drop brackets. This set up is IMPRESSIVE to say the least. You may ask yourself how do you run a 6" coil with Duff 2" axle pivot drop brackets? the answer is we built custom 3" cut and turned beams........
I tried tweaking my Duff lift in several different ways to get the clearance I wanted, but eventually foudnt he Duff coils were too stiff for my liking and the Duff shocks, well you mine as well run solid links in there, they are way too stiff...........
Good luck!
