jd4242
- October 15, 2008
- va beach
- 92explorer&94 ranger
easier yes but still in the way!!you can all most see it stamped in the pic,in the middle of the head behind the springs under the rocker arm shaft.could be but man thats bad either way,bad oil means high heat low lube witch means worn bearings.also high heat is very bad for those heads if they are stock
