Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
Just bought a '99 Mountaineer
- Thread starter GSmithFL
- Start date
- Tags
- 1999 99 mountaineer
Add an avatar, upload photo attachments, and more!.
- February 2, 2002
- 1998 Mountaineer AWD
V6 or V8?
By now these usually needs some fixes, or are showing their quirks.
GSmithFL
- May 16, 2019
- 1999 Mercury Mountaineer
It is the V6. I wanted a V8, but the unexpectedly quick sale of my old Saturn dictated a quick purchase.
Most of the Mountaineer's issues are cosmetic... or so I thought until after I signed the papers.
During the test drive I never got the truck over 50mph as the seller lives in the middle of this huge suburban enclave on the west coast of Florida. The nearest actual free flowing highway was over 20mins away.
Anyway, on the way home after the sale I got the flashing "O/D OFF" light. The transmission was still running buttery smooth, no smells, no noises, and I checked the fluid again. It still looked fine: good color, not dirty, no metal bits, no bad smells, etc. But I did notice that it was a little bit over the max "dot" on the dipstick and into the crosshatches. Could it just be overfilled?
I don't think the overdrive is kicking in: 60mph translated to 2800rpm on the way home. I think that should be lower?
I will look through the forums and see what I can find.
Thanks!
Thanks!
- February 2, 2002
Yeah, that seems high for 60. The flashing OD means there is a stored transmission code. The level may seem high due to the fluid being overheated. The V6 transmissions aren’t the stoutest.
It doesn’t make any abnormal noises (rattles) on a cold start up does it?
GSmithFL
- May 16, 2019
Nope, no rattles that I have heard. It runs phenomenonally.
Could the light just be the TCC issue (did some reading last night). The light doesn't appear until the truck is warmed up and we get to highway speeds.
- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Welcome to this forum! Find out what the code number is for the transmission issue, and don't continue driving it. The transmission feels fine because it's in FMEM mode, and the EPC solenoid raised the line pressure to compensate for the fault. The rattle might be coming from the timing chain & tensioner. What is the mileage?
- February 2, 2002
The rattle is almost surely why the truck was sold. It’s the timing chain guides being worn or broken. Common issue on these 4.0s. Usually happens on a cold start after they loose their prime.
Yes, you have a 5r55e.
- February 2, 2002
I’d get the transmission diagnosed first. If the transmission needs an overhaul I’d question whether or not I’d be fixing it.
- November 11, 2005
- Brooklyn, NY
No, but they have blown out valve body gaskets around the area of the EPC solenoid.
GSmithFL
- May 16, 2019
And how bad is that?
- February 2, 2002
Pan drop, and valve body removal. Way easier than the timing chain repair.
Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 2005 2WD Regular Cab F150
GSmith, welcome.
GSmithFL
- May 16, 2019
Thanks!GSmith, welcome.
GSmithFL
- May 16, 2019
So, I had Auto Zone rear the codes since mine is a basic reader. They did not come up with any tranny codes.
We only came up with:
P0113
P0102
The O/D light stayed off this morning until I got on the highway. It averages 20-22mpg on the highway, which seems about right. Not sure the tranny is misbehaving.
Maybe the fluid is too high? Do I need to get someone else to read it?
P0113
P0102
Mike65
- December 31, 2013
My wife's 99 Sport has had the flashing OD off light since we purchased it 7/2015. I tried to replace the torque converter solenoid on the valve body & it worked good for a while & then it started acting up again. Once she has driven it for a while the light comes on again.
Similar threads
- Replies
- Views
- 1,450
- Replies
- 7
- Views
- 1,481
- Replies
- 19
- Views
- 52,064
- Replies
- 34
- Views
- 6,281
- Replies
- 15
- Views
- 2,050
