avidmar1978
- May 26, 2012
- 2000 Ford Explorer Sport
I just purchased a 2000 Explorer Sport with 145,000 miles on it for $900. It was, of course, not without issues. The body is pretty rough, quite a bit of rust around the bottom on both sides, and the rear. The rust, I'm just going to have to deal with. It would probably cost more to fix it than the vehicle would be worth after it was done. I've already fixed a half dozen or so things, which is pretty good for me, as I've never considered myself good at working on vehicles.
Here's where I need some help:
1) Missing rear Wiper arm - I bought a replacement arm at the junk yard, but there is a nut rusted onto the existing rod that sticks into the motor. I can't grip the rod tight enough to get the nut off, even with a vice. Worst case, I go back to the junk yard and get a new rod. Any other options?
2) Power Door Locks - None of the switches work, won't lock or unlock. The keyless entry pad works, though. All fuses are good, so I'm guessing it's the relays in the black box that is pictured, but never referenced, in this thread: http://www.explorerforum.com/forums/showthread.php?t=195398. I can't find any diagrams for that relay box to tell me which relays do what? I can get new relays, but I don't know which ones. I currently only have 4 relays in there, with multiple open slots. A little help would be great.
3) Driver side door handle - Not really working. The interior spring broke and the previous owner used a zip tie to re-attach. I can't tell if that's the only thing wrong or not. It does still open the door, though just barely.
4) Lift gate / lift gate glass won't lock - I picked up another lock chamber (the part you put the key into) at the junk yard, but I realized that it probably won't work with my existing key! Not really sure how to fix this. Will this get fixed by fixing the power door locks?
I just found this site 2 days ago, and I love it so far!
