Derrick Adams
- May 18, 2011
- North Central Ohio
I'm getting ready to purchase some wheels and lift for my 03 Mountaineer. I want to run 305/60/18s (32.5x12.5) Nitto Terra Grapplers mounted on 18x10 Helo rims with 6.88" BS. I will run adaptors to clearance the wheels as needed. I'm also not afraid of cutting and clearancing bumpers, inner fenders, fenders, etc for them to fit.
I have read that 33's will fit with the 3" body lift. So how much more clearance problems should I expect with the 10" wide rims vs. the normal 8.5"?
Secondly, since my Mountaineer has the puny hitch behind the bumper cover should I expect it to have the 3.55 gear center cases? In which case I need to source a set of larger cases to accept new ring/ pinion?
