kenwood amp | Ford Explorer Forums
kenwood amp
88vert
clinton,iowa
94 unlimited
Does anyone know anything about a KAC-920 Kenwood amp,like size,or if they are any good or not,looks like older model,heavy.thanks alot guys Brad in Iowa
it should be a decent subwoofer amp. a little overrated as far as rms power goes, but still a good amp.
amp
Thanks for the input.I have three kove armaggedons ran in series,i had a jensen four channel 600 watt amp powering them and it hit pretty hard.Do you think this Kenwood will come close to the jensen?Thanks again Brad in Iowa
they both rate their amps @ 14.4 volts. so performance should be similar watt for watt. they even have the smae signal to noise ratio and THD.
i would recommend more power to those armageddons, but this should still work. what series are the subs? they're not the armageddon U series, right?
They are the dual 4ohm z series.I am looking at buying either a excelon or MA mono block.For a jensen amp it really made those subs pound.Thanks alot leejen
those MA audio mono block amps perform great.
the excelon amp is good too. but the MA audio amp is better suited to competition. it will run cooler, and it can handle more abuse. good luck with whatever amp you get.
thanks for your help leejen.i will probally go for the mono block,the kenwood is just for back up,cannot go with out bumps.Thanks again Brad in iowa
