Kevlar Vs. Ceramic Brake Pads | Ford Explorer Forums
dkolewaski
Sherwood Park, Alberta
'96 XLT 4x4
Hey all i have been thinking about going to either one of these pads and was just wondering if i have to change out the rotors to some special coated ones or something to use these pads? any one using these? notice big differences?
Not sure if this is applicable, but I put some Satisfied Pro Ceramic pads on my g/f's 03 Honda Civic EX coupe that she had. Not sure on changes in braking, but the brake dust was crazy :thumbdwn: Tons of it :thumbdwn: Very difficult to remove :thumbdwn: To remove it totally, I used Simple Green and fake Scotchbrite pads. Got sick of them, and switched back to OEM pads.
i thought that ceramic and kevlar pads were not supposto have a lot of brake dust, are you sure you got the real thing?
I have Bendix CT-3 ceramic pads on my DD, and I have been very happy with them. They are the smoothest, quietest pads I have every used. No noticeable brake dust after two months. Equivalent stopping compared to the semi-metallics I normally run, with less fade on long descents. Less fade could only help a heavier vehicle like a 'sploder. I also followed the manufacturers recommended break-in cycle (burnishing):
"A series of controlled moderate speed stops (15-20 Stops from 30-mph w/30 sec cool down) is required to properly "burnish" or break-in a new set of pads. During this initial stopping period, the process of lining transfer from the disc pads to the rotor surface helps condition the rotor surface to properly seat the brake pads. All pads are cured and all pads need to be burnished."
from http://www.bendixbrakes.com/techCorner/faq.php
Also worth noting - I replaced my rotors when I installed the new pads, using the standard rotor, no special coatings and no problems so far. Be sure to check the manufacturers recommendation's for the specific brand of pad you want to use. At a minimum, have your rotors re-surfaced, but remember you are removing material and the rotors will be more prone to warping because they will not be able to dissipate heat as effectively.
Ceramic pads, unless it's a race application, seem to be developed and marketed as quieter alternative to semi-metallics. Ceramic pads, in theory, cause less wear on the rotor and produce less brake dust.
I have no experience with kevlar pads, sorry. The ceramics I am using are noticeably better, but not a dramatic improvement in braking performance. Hope the info helps!
hey thanks a lot for the info
