LongStrangeTrip
- December 13, 2019
- Klamath Falls, Oregon
- 93 Sport 5spd man tcase
Hey all,
New-ish member, first post. Long time lurker and consumer of knowledge on here.
I’ve got a 93 Explorer Sport, 5 speed, manual T case, manual hubs. 120k miles.
I have owned this vehicle for 3 or so years now, I’ve been fighting an issue that I just cannot seem to resolve. I drive it 2.5 miles to work every day, when I am feeling lucky. The issue has changed (sort of) over the years, but has always been present in some way. I’m at my wits end, hoping to get pointed in the correct direction here. I have crossed a lot of normal maintenance items off of the list, some 2 or 3 times out of frustration. I never get a CEL, I have a proper code reader and only ever get 556 in memory codes for fuel pump circuit.
It’s current state is as follows…
Cold start, above 50 degrees: High idle attempts to engage but is sporadic swinging between 1800 and 400 rpm, nearly dying but doesn’t. Engine is backfiring during this. After 5-7 minutes, the idle starts to improve and backfiring becomes less. After engine to operating temperature, the idle settles around 900 rpm, swinging between 800-1000 randomly. Occasional misfiring. If I unplug IAC at this point, the idle smooths out and misfire stops, idle sits at 1000rpm. Even when warm, vehicle is sluggish, seems to have some pinging, definitely have to be cautious if taking off on an incline due to lack of power.
Cold start below 50: hard pressed to keep it running with foot on pedal.
Here is what I have done over the last few years…
Spark plugs
Spark plug wires
Tested coil output
Replaced battery
Replaced alternator
Cleaned intake
Replaced all vacuum lines
Replaced EGR and solenoid
Replaced evap canister and solenoid
Replaced pcv valve
3 replacement IACs
2 Intake air temp sensor
2 coolant temp sensors
2 fuel caps (one stolen)
2 throttle position sensors
Tightened intake bolts
Replaced Throttle Body
Cleaned MAF sensor
Smoke test on engine for vacuum leaks
Eliminated items like brake booster for testing
Checked voltage at IAC
Checked voltage at fuel pump
Checked fuel pressure
Replaced fuel pump relays
Cleaned grounds
Cleaned & added dialectic to all connectors
I’m sure a few other things I am forgetting. I used Motorcraft parts when available.
I bought a used throttle body off of a runner but it was an automatic. So I thought maybe base idle trim could be different and messing with pcm. So I attempted to reset idle with IAC unplugged. Idle will not go below 1000 with IAC unplugged, and screw backed out to where no longer affecting base idle.
I keep thinking vacuum, but I can’t find it. I have put half of a can of ether in the engine compartment hoping to find a secret vacuum leak with an increase in idle, but never can.
Someone suggested replacing PCM, but sometimes it seems to run pretty good, I feel like a pcm failure would be permanent.
The colder it gets, the worse the issue is.
Can someone please help me out? I’ve always done my own wrenching, I’d hate to have to take it to someone.
Spark plugs
Spark plug wires
Tested coil output
Replaced battery
Replaced alternator
Cleaned intake
Replaced pcv valve
3 replacement IACs
Cleaned MAF sensor
Cleaned grounds
