LC arm to rear hub assembly - torque spec? | Ford Explorer Forums - Serious Explorations
Swamp Fox
Pee Dee Region - SC
'04 XLT 4WD K-flex 4.0 V6
Does anyone know what the torque spec is for the bolt that connects the lower control arm to the rear wheel hub assembly. About to put the hub back on after new bearing has been pressed in. As far as I know the axle nut is 203 ft/lbs and the pinch bolts are 66 ft/lbs. Thanks for any help.
Thanks for the info. Ready to get it back on the road as soon as possible.
