Torque specs. | Ford Explorer Forums - Serious Explorations
Torque specs.
Hunter3006
Shippensburg, Pa
2002, Explorer, Limited
Good afternoon, I need some torque specs for 2002 4.0. I appreciate any help.
Valve cover bolts
Upper intake
Front axle nut
Front bearing hub bolts
Ill grab them in a bit if i get out to shop or tomorrow if you still need them.
Intake or upper plenum 89in lbs or 7.4ft lbs. Same for valve covers. I think there is also brass inserts in the intake to keep from crushing it. Not saying to try too either though lol also just use your best judgement and good luck!
Thanks to the both of you, this info will be put to good use when I get the parts on Tuesday.
