lexplorer
- July 24, 2002
- burlington ontario,canada
- '92 XLT
Just changed my starter and a day later I had a massive transmission leak.. (agood puddle) I had checked the pan bolts and most were pretty loose ,so i tightened them and decided to get new gasket put on as well and thought that would be the end of it.. wrong .. The leak is coming from passenger side just above pan , but I can't see exactly where . Could I have disturbed the cooling lines or is it probable a seal in trans. 92 2wd.I can do most work myself except for rebuilding trans. Should I just bite the bullet and take to trans shop and have them figure it out ... thanks..
