LED Front Turns | Ford Explorer Forums
LED Front Turns
jsgoofn
Beautiful Colorado
2022 Explorer ST-Line
I am hoping that out there in Explorer land, there is someone who has successfully installed LED Front Turn signals either with or without resistors that can help me figure out a problem. I installed some high quality LED front turns (3157) and successfully changed the programming to stop the hyperflash. The problem I have is with the lights on, the bulb barely pulses to show that it is blinking. It works perfectly without the lights (such as in the daylight). I have attached a video to show what it does. Does anyone have this problem and if so, how did you fix it? Thanks in advance!
What is your DRL setting set at? The signal lamp CAN be set as the DRL ... maybe that got changed in error?
I only changed the bulb outage code. I didn't touch the DRL. But thanks for the suggestion!
I was just looking at your posted video of your LED installation and so I am guessing you have not had the same problem as me with the lights on. So, what type LEDs did you get? Maybe the ones I have are just not correct for the Ex.
These are the ones I got for my 13 and transferred to the 16. Now in the 16 there isn't a amber parking light on mine (most don't) so the hyper-flash doesn't happen OUTSIDE but does inside with the clicker.
On my 13, if the parking lights were ON, yes you'd get hyper inside and out but if the parking lights were OFF it was "normal" flash.
Lighting description -
JDM ASTAR Extremely Bright PX Chipsets 3056 3156 3157 4157 LED Bulbs ,Amber Yellow(Brightest Turn Signal Bulb on the Market)
by JDM ASTAR
Link: http://a.co/28XNRW6
Maybe I didn't clarify enough...what I meant was I DON'T hyperflash on either setting. With the parking lights on, my turns blink but are barely visible (see the video). I was wondering if you noticed if your turns blinked normally outside with the parking lights on.
Sorry I missed that or saw a squirrel ... yes mine blinked without issue.
This was my 13
Thanks... I saw your video before but it showed your turns without the other lights on. But in the meantime, I got a reply from a tech expert that explained something about the circuit board on the LEDs themselves might be causing the problem so I ordered some others and we'll see what happens when I install them.
Squirrel!
Well, I can finally close out this long post...I purchased some Sylvania ZEVO 3157 LED bulbs from O"Reillys yesterday and just installed them and everything finally works as it should. These bulbs are pricey but are warranted for life. I contacted a tech from Sylvania and he assured me that the 3157 would work fine (the OEM bulb is 3457). And thanks to @cwescapexlt4x4 for helping me out. On to the next project - swapping out the OEM bulb in the puddle light.
https://www.amazon.com/SYLVANIA-ZEV...r=8-1-spons&keywords=sylvania+ZEVO+3157&psc=1
This was my 13
Hey Chris... Hope things are going well with you. I think you and I exchanged a few messages awhile back. I had asked you about the LED change out on your '13 for the turn signals. I am planning on doing this on my '15 just for the front parking light/turn-signal and wanted to ask how hard the headlight housing was to get at to change the front lights. Also, I have read that by only changing out the front turns, I can avoid dealing with the hyper-flash issue (I'm ok with leaving the condensates in the rear since they are only on with the turn-signal) . I have had my DRL's turned on (parking light cause of HID's) and I am looking at the JDM ASTAR 1260 Lumen Amber blubs.
I would appreciate your input....Thanks
Hope you don't mind me answering.... I have a '15 and I had no problem getting to the front turns to change the bulbs. And i think the turns still hyperflash even if you only replace one set. But I guess you will find out. I know that some companies suggest resistors to stop the hyperflash but I didn't feel comfortable with creating more heat.
On both my '13 and '15, I found it easier to get the front turn signal bulbs out by removing the little metal tower thing for the hood. It's one 8mm bolt. You will have the hyperflash, unless you turn it off with Forscan, or put in a resistor.
I used Philips LEDs for everything except headlights and fog lights, because they're readily available at Autozone, O'reilly's or Advance Auto Parts.
Thanks jsgoofn and Jon M. I appreciate the feedback. I wasn't sure I could get to the parking light/turn-signal with just removing the hood bumpers. I had read somewhere that loosening the whole assembly was necessary. I managed the side markers no problem. Just had to play with the socket a little to get it out.
I had updated my '94 Splash front parking lights/turns with LEDs and just had to put a no load turnsignal controller to avoid the hyper-flash. Ran it that way for a couple of years. Didn't know if the explorer had something similar or not. I haven't picked up a forscan yet, but it is on the list for this summer's tool acquisitions. :)
The Forscan software is free, and you can the cable with the switch for $35 or less on eBay or Amazon.
Thanks Jon...I was looking at this USB OBD2 ELM327 to connect to my Ex with:
USB Modified OBD2 ELM327 For Ford MS-CAN HS-CAN Mazda Forscan Diagnostic Scanne 601404257450 | eBay
And...looked at www.FORScan.org for the download. I'm guessing that is the correct website. Should work with my Dell laptop running Windows 7 Pro. I ordered the LED's this past Monday and will get the ELM327 next week. Then I guess the fun begins...lol.
Thanks for all the feedback and suggestions. They have been appreciated!
It's been a few years now since I've had the 13 but I don't seem to recall the bulb removal/install being that difficult but I could be incorrect.
Forscan is free yes as is the license but you have to have the 3 month trial license to make the mods to the Ex software.. It is free but you need apply.
