Don’t know the specifications on stock LED, looking for something a little brighter. I will check stock LED’s and find out the color temperature rating. Thanks
I don't think you can change the low beam on the 18's. I believe they are all LED built into the housing. Maybe upgrading the foglamps would be a better option...that is if you have halogen fogs & not the LED ones otherwise your only option may be to mount some aftermarket driving lights in the grill
The 2018 came with Phillips/Osram 5500k lumens in your low beam only! If you want to perfectly match them with your high beam, here is your best source for true Philips upgrades. Search by bulb type, not by vehicle as they will not list for legal reasons anymore. The high beams are 9005’s. These are “clockable” but work perfectly set at “O” as the beam pattern relics the incandescent perfectly! I have these in various sizes, motorcycles h7’s, atv’s h4’s, trucks, etc and yes, my ‘16 sport. I have NEVER experienced a failure in many, many years of use on any vehicle(s). Cost’s more but you get what you pay for! There truly is no argument for the best! The quality of light, beam pattern and unbelievable improvement will blow your mind!. No canbus adapter needed for the explorer, simplistic plug and play install…
One more tip, For those of us that have the useless amber incandescent in our fogs before Ford upgraded in late ‘16, here is an inexpensive and reliable solution. I leave the “lenses” off and this too will perfectly match the color of your led low beam. These are very bright and produce a significant wide pattern. These are actually 9145’s vs h10’s so “get ready to live” when you upgrade your fogs to these!
This premium H10 LED Kit will increase your visibility and your safety by improving your vehicle's lighting. Self-confident installation more than ever.
