LED headlights | Page 3 | Ford Explorer Forums
LED headlights
ok,, devils advocate here cause i can,,.
did you clock the leds so they were throwing the light in the proper locations? or just put them in and hope for the best ??
every set of leds has a ring around them that can be moved to adjust where the led actually is and where it shines,, it makes a huge difference if this is properly done
i have a set in my 08 Ranger and it wasn't till after i adjusted them proper did i really appreciate how they work, such white light to go with my 30 inch light bar,,
Yes I did it with all four led light bars it took a few minutes to get right because of how bright they are and my Explorer is lifted. So take the time to get it right.
I put opt-7 led in my fog and high beam on my 04 explorer and will probably put a set in my low beam as well I have used the opt-7 in several vehicles and been very happy
